I honestly have no idea what is the best way to find RL for maximum power transfer in this circuit. enter image description here
What I do know, first and foremost, is that the RL resistor can be found as the Thevenin-equivalent resistance, R_th. I believe superposition is usually a good way to solve circuits like this, but even if I try to remove the current source and short-circuit the voltage source, I still have the dependent sources that complicate things further.
I tried removing the RL resistor first, so that perhaps I can find V_th as the open circuit, but the placement of the resistor really sets it at an awkward position, because there's also a dependent source at the bottom half that I can simplify with the mesh-current method. I tried using mesh-current method to set up a supermesh at the bottom half of the circuit, but even with that, both dependent sources are based off of i_A and v_A. A similar problem happens the same when I attempt to use node-voltage method, in that while I can setup a supernode along the voltage-controlled dependent source, there still remains the other current sources.
I really don't want to give up on this problem, but the more I try to make sense of this circuit, the more confused and frustrated I get. Can someone please help here? What am I doing wrong?
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
