I am debugging an H8S MCU in Renesas High Performance Embedded Workshop 4 with the attached E10A emulator, and find it's very slow when stepping through code because it keeps reflashing the chip between some lines, but not all.
I could understand it reflashing if I change breakpoints, but not when there are no changes at all.
This is what the debug panel shows after a a bit of stepping, most of the flashing are after using F10 just to go the next line.
Each reflashing takes up to 10 seconds.
RUNNING
BREAK KEY
Flash memory writing ...
Flash memory write end
RUNNING
BREAK POINT
RUNNING
BREAK POINT
STOP ADDRESS
STOP ADDRESS
STOP ADDRESS
STOP ADDRESS
RUNNING
I'm sure at one point I got it to stop doing this and it just stepped instantly, but I seem to have lost the setting.
Before I spend hours trying to solve it, I wondered if anyone knows if this is just how it is?
