I am new to matlab. I was working on a simple modulator that I have to simulate. I've faced a problem with connecting the output frequency from the resonance circuit to the scope, A red dotted line appears. After further googling and searching in mathworks, I've found a converter to connect them.
Now my problem is in the input signal. I am applying a signal generator to the input which is the join that collects a capacitor and resistor to the transistor base, the below images shows the whole circuit :
Circuit
Now I found this converting tool : https://www.mathworks.com/help/physmod/simscape/ref/simulinkpsconverter.html
But it still cannot be connected to the joint that I want. check this:
Circuit
Anyone can suggest what's wrong with this type of connections and how to fix this? Noting that I am using matlab 2018.
The issue here is physical domains.
The black traces are the traditional simulink s-domain traces
The brown signals are physical but domain agnostic trace
The Blue signals are the electrical domain traces.
You have found the Simulink to Physical port converter to map a simulink signal into the Simscape domain, now you need a source for this signal to control. A voltage source should be all you need
How to shift signal phase in matlab from this circuit?
Trying to simulate a simple micro inverter, Cant connect scope
  • \$\begingroup\$ Thank you very much :) .. You've solved my problem. \$\endgroup\$ – B Happy Dec 15 '18 at 19:34
