My DC motor's nameplate says:
VOLTS: 125
AMPS: 27A
HP: 4 HP
RPM: 5000 RPM
DUTY: CONT.
I chose this IGBT IKW50N60DTP to drive the motor with a PWM frequency of 5 kHz using a single-quadrant chopper.
My question is: For the power calculations, do I need the max load current of 27A (average IGBT current value?), even if I don't plan to reach that value of current?
I'm following this app note to do my power calculations and it suggests I need the IGBT average and RMS current.
    \$\begingroup\$ Unless you accelerate very slowly (rate of V/f ) the surge current while starting is 45A for 4HP @ 125V regardless of the load due to the DCR of the motor coil. \$\endgroup\$ – Sunnyskyguy EE75 Dec 15 '18 at 16:34
