I'm now writing a testbench. In my testbench, I want to read the length of a text file and pass it to another module while instantiating. The idea is like this:
module TB();
integer text_len;
ABC #(.text_len(text_len)) ABC_1(//some input/output arguments here);
task read_text(output integer text_len);
//read text file and get the text length
endtask
initial
begin
read_text(text_len);
end
endmodule
When I compile it using Questasim, it keeps saying the expression for a parameter actual associated with the parameter name text_len for the module instance ABC_1 must be constant. Does anyone know how to deal with it?
The problem is module instantiation happens at code elaboration before the simulation of any initial blocks. So you cannot use a variable to override a module parameter.
What you can do is parse the file externally to Verilog and either create a `define definition that you compile your source code with, or Questa allows parameter overrides through the command line (look for the vopt -g/-G switches in the user manual)
The defines.vh file would look like
`define TEXT_LEN 5
And your module file would look like
module TB();
`include "defines.vh"
ABC #(.text_len(`TEXT_LEN)) ABC_1(//some input/output arguments here);
  • \$\begingroup\$ Thanks for your help. Could you explain a bit more on the first method? I'm still new to verilog... \$\endgroup\$
    – hk56740
    Dec 18, 2018 at 1:33
  • \$\begingroup\$ Edited answer with an example \$\endgroup\$
    – dave_59
    Dec 18, 2018 at 1:47
  • \$\begingroup\$ Also, it might help to explain why you want to do this as there might be a completely different approach, especially if this is for a testbench. \$\endgroup\$
    – dave_59
    Dec 18, 2018 at 2:06
  • \$\begingroup\$ I want to create a checker so that I can check if the data output from a module is correct or not, but at the same I don't want to fix the size of the reg containing the sequence which is for me to check the data so that I can use any sequence for me to do the job. Thanks for your help! \$\endgroup\$
    – hk56740
    Dec 18, 2018 at 11:59
  • \$\begingroup\$ If you are using SystemVerilog, why not use a dynamically sized array instead of trying to fix the size of the data? \$\endgroup\$
    – dave_59
    Dec 18, 2018 at 15:40
