I wanted to create a 10-200 lbs scale using a FX1901-200 lbs load cell (https://www.digikey.ch/product-detail/en/te-connectivity-measurement-specialties/FX1901-0001-0200-L/223-1531-ND/5277314), a sparkfun HX711 (just the chip wired on a board), and a raspberry zero to make that happen. So I wired it up like this (I tried to wire yellow to ylw but that just wouldn't work at all, but it sorta works on grn, also white between the Raspberry and the chip goes to ground, its a slightly of center):
And ran this code:
#!/usr/bin/python3
from hx711 import HX711
import sys
import RPi.GPIO as GPIO
import math
import statistics
import os
import datetime
try:
print("connecting")
hx711 = HX711(
dout_pin=23,
pd_sck_pin=24,
channel='A',
gain=64
print("resetting")
result =hx711.reset() # Before we start, reset the HX711 (not obligate)
if result:
print("success")
else:
print("failure")
raise ValueError("")
print("connected")
while(True):
measures = hx711.get_raw_data()
mea=sorted(measures)[2]/10000
mea=int(mea)
#val=math.floor( math.log(abs(measures[0]))*10.0 )
val=measures
print(str(mea) + "\t" + str(val) + "\t\t\t"+str(datetime.datetime.now()))
print("█"*(int(mea/5)))
finally:
GPIO.cleanup() # always do a GPIO cleanup in your scripts!
print("cleaning up")
But the readings I get are terribly inconsistent and as soon as more than ~90lbs of pressure are applied, the cell sort of crashes and only gives negative readings no matter the load:
connecting
resetting
success
connected
15 [315807, 158020, 78229, 78288, 6541823] 2018-12-18 18:48:43.137149
WARNING:root:setting gain and channel took more than 60µs. Time elapsed: 0.00012506
31 [156657, 318123, 318723, 318713, 159441] 2018-12-18 18:48:45.787850
20 [157779, 319793, 320439, 192117, 209145] 2018-12-18 18:48:48.011792
43 [437001, 258052, 7888895, 5570559, 154869] 2018-12-18 18:48:49.244843
37 [1907415, 373321, 170746, 220077, 466669] 2018-12-18 18:48:51.051037
28 [467875, 234919, 256529, 285642, 287557] 2018-12-18 18:48:52.676789
35 [550539, 549965, 276906, 352081, 278266] 2018-12-18 18:48:54.303139
12 [127284, 126625, 125814, 124966, -6553601] 2018-12-18 18:48:55.640389
23 [246439, 239414, 115064, 228829, 447631] 2018-12-18 18:48:57.266976
44 [445075, 442543, 440237, 219052, 105688] 2018-12-18 18:48:58.099545
40 [211267, 411997, 410381, 408623, 407239] 2018-12-18 18:48:58.943753
39 [406205, 809083, 98400, 196181, 390213] 2018-12-18 18:49:00.173517
55 [194594, 240565, 550689, 553729, 555229] 2018-12-18 18:49:01.413470
28 [556783, 280107, 281821, 284658, 141996] 2018-12-18 18:49:03.029772
28 [284305, 289232, 287863, 583893, 603753] 2018-12-18 18:49:05.147853
WARNING:root:setting gain and channel took more than 60µs. Time elapsed: 0.00012802
-2 [607129, -24488, 1769471, -23315, -21833] 2018-12-18 18:49:08.060169
-1 [-14672, -16817, -16036, -12625, 16747] 2018-12-18 18:49:10.967555
0 [17259, 18535, -10735, -2043905, -9326] 2018-12-18 18:49:15.874284
0 [-9208, -8518, -8756, -9313, -11094] 2018-12-18 18:49:17.532877
-1 [-18885, -18693, -18598, -19075, -18987] 2018-12-18 18:49:19.369511
-1 [-19012, -19027, -18971, -18952, -18915] 2018-12-18 18:49:21.070971
-1 [-18902, -18862, -18876, -18984, -19028] 2018-12-18 18:49:22.059373
-1 [-19039, -19050, -19064, -19030, -19007] 2018-12-18 18:49:22.681170
-1 [-19078, -19127, -19118, -19085, -19022] 2018-12-18 18:49:24.025283
-1 [-19015, -19219, -19203, -19185, -19209] 2018-12-18 18:49:25.546960
-1 [-19212, -19233, -19203, -19213, -19266] 2018-12-18 18:49:27.237327
-1 [-19309, -19352, -19346, -19336, -19342] 2018-12-18 18:49:28.403525
-1 [-19392, -19407, -19307, -19265, -19180] 2018-12-18 18:49:29.571867
-2 [-4894, -8942, -23532, -23257, -22924] 2018-12-18 18:49:32.612460
-2 [-23036, -22834, -26684, -27857, -27999] 2018-12-18 18:49:34.123481
-2 [-28268, -28577, -28627, -28630, -28401] 2018-12-18 18:49:34.934208
-2 [-28107, -27639, -27481, -27301, -27442] 2018-12-18 18:49:35.733815
-2 [-30676, -29016, -28033, -27867, -27800] 2018-12-18 18:49:37.791934
Has anyone have any Idea what I could be doing wrong? It does sort of work with small forces up to around 70-80 but it still goes into the total negative sometimes and about half of the readings are completely random.
