Without more context we can't be 100% certain, but most likely this is because conversion from optical to electrical signals is very often a square-law process. That means that in an O/E converter the power in the electrical output generally varies as the square of the power in the optical input. This is because the current in the detector is generally proportional to the incident optical power and the power in the electrical signal is proportional to the square of the current.
So, if you have some bandwidth restriction in your optical path and it reduces the optical power by 3 dB, after passing through the photodetector the electrical signal power will be reduced by 6 dB. If you assume a single pole filter effect, you'd have to reduce the modulation frequency by a factor of \$\sqrt{2}\$ to find the frequency where the electrical signal is reduced by only 3 dB.
So your book's statement depends on a number of preconditions that should be stated somewhere in the text:
- You're detecting the optical signal with a square law detector
- The modulation response of the channel has a single-pole characteristic (this is pretty likely to be a reasonable assumption for the given case of measuring the modulation bandwidth of an LED. If we were talking about the bandwidth of an optical fiber transmission channel it might not be a very good assumption)
- We define the bandwidth of the system by the frequencies with 3-dB attenuation relative to the peak response
- etc.
In some other context you might, for example, define the optical bandwidth by the frequency with 6-dB attenuated response, while still defining the electrical bandwidth by the frequency with 3-dB attenuated response. Then you'd have the same bandwidth figure measured either way.
