I understand that RAM is connected directly to the CPU via a high bandwidth bus, and SSD is a peripheral, but my assumption is that there are also electrical design differences (e.g. memory cell design and layout) that make RAM faster than SSD for reads/writes. If that is true, and with bus bandwidth & latency differences aside, what are those design differences, and how do they affect speed?
closed as too broad by Eugene Sh., Chris Stratton, old_timer, Finbarr, Edgar Brown Dec 20 '18 at 22:01
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
The biggest difference is that SSDs are based on NAND flash cells with the serial structure shown below.
NAND flash structure
Where DRAM accesses all of the bits in a row at the same time, NAND flash serially accesses the row. This significantly slows down read access versus DRAM.
Write access is significantly slowed because flash uses a floating gate which requires orders of magnitude more programming time than the capacitor in a DRAM cell. In most cases, since the write can only set a bit to 0 and erasing is required to set a bit to 1, writes also require erasing before programming. DRAM writes can set either state with no speed penalty.
Their physical structure is totally different. DRAM cells are based on a capacitor holding its voltage.
Flash is based on a floating gate design, where the physical properties of the cell changes with a write.
    \$\begingroup\$ How does this affect r/w speeds? \$\endgroup\$ – JBaczuk Dec 19 '18 at 16:53
    \$\begingroup\$ This is more than too broad. \$\endgroup\$ – Eugene Sh. Dec 19 '18 at 17:23
    \$\begingroup\$ I'm wondering why a capacitive memory cell (DRAM) is faster than a floating gate cell. \$\endgroup\$ – JBaczuk Dec 19 '18 at 17:42
