I have a lattic X03LF starter board with 6900C FGPA. There are eight LED available on this board and a push button.
The goal of my code is to design a 8 bit counter that increments whenever a button is pressed. Also there is another button available that is used for resetting the device.
Since the led work on active low signal, i have the counting start from 0xFFh, 0xFEh, 0xFCh...
Below is the design module for the counter,
module led_counter_starter_kit(
output reg [7:0] led_out,
input sw_n,
input reset_n,
input clk,
output [7:0] cur_st,
output [7:0] nex_st
reg [7:0] current_state;
reg [7:0] next_state;
parameter S0 = 8'hFF;
parameter S1 = 8'hFE;
parameter S2 = 8'hFC;
parameter S3 = 8'hF8;
parameter S4 = 8'hF0;
parameter S5 = 8'hE0;
parameter S6 = 8'hC0;
parameter S7 = 8'h80;
always @(posedge clk) begin
if (~reset_n)
current_state <= S0;
else
current_state <= next_state;
end // always @(posedge clk)
case (current_state)
S0: begin
if (~sw_n) begin
next_state <= S1;
led_out <= S0;
end
else begin
next_state <= S0;
led_out <= S0;
end
end
S1: begin
if (~sw_n) begin
next_state <= S2;
led_out <= S1;
end
else begin
next_state <= S1;
led_out <= S1;
end
end
S2: begin
if (~sw_n) begin
next_state <= S3;
led_out <= S2;
end
else begin
next_state <= S2;
led_out <= S2;
end
end
S3: begin
if (~sw_n) begin
next_state <= S4;
led_out <= S3;
end
else begin
next_state <= S3;
led_out <= S3;
end
end
S4: begin
if (~sw_n) begin
next_state <= S5;
led_out <= S4;
end
else begin
next_state <= S4;
led_out <= S4;
end
end
S5: begin
if (~sw_n) begin
next_state <= S6;
led_out <= S5;
end
else begin
next_state <= S5;
led_out <= S5;
end
end
S6: begin
if (~sw_n) begin
next_state <= S7;
led_out <= S6;
end
else begin
next_state <= S6;
led_out <= S6;
end
end
S7: begin
if (~sw_n) begin
next_state <= S0;
led_out <= S7;
end
else begin
next_state <= S7;
led_out <= S7;
end
end
default: next_state <= S0;
endcase // current_state
end
/*always @(posedge clk) begin
if (~reset_n)
led_out <= S0;
else begin
S0: led_out <= S1;
S1: led_out <= S2;
S2: led_out <= S3;
S3: led_out <= S4;
S4: led_out <= S5;
S5: led_out <= S6;
S6: led_out <= S7;
S7: led_out <= S0;
endcase // case(current_state)
end
end // always @(posedge clk)*/
assign cur_st = current_state;
assign nex_st = next_state;
endmodule // led_counter_starter_kit
and the test bench for this design is below:
`timescale 1s / 1s
`include "led_counter_starter_kit.v"
module starter_kit_counter;
reg clk;
reg sw_n;
reg reset_n;
wire [7:0] led_out;
wire [7:0] cur_st;
wire [7:0] nex_st;
initial begin
clk = 1'b0;
forever begin
#1 clk = ~ clk;
end
end
led_counter_starter_kit Test (.led_out(led_out),
.sw_n(sw_n),
.reset_n(reset_n),
.clk(clk),
.cur_st(cur_st),
.nex_st(nex_st)
initial begin
@(posedge clk) reset_n = 1'b0; sw_n = 1'b1;
@(posedge clk) reset_n = 1'b1; sw_n = 1'b0;
@(posedge clk) ;
@(posedge clk) sw_n = 1'b0;
@(posedge clk) ;
@(posedge clk) ;
@(negedge clk) sw_n = 1'b1;
@(posedge clk) ;
@(posedge clk) ;
@(posedge clk) ; sw_n = 1'b0;
@(posedge clk) ;
@(posedge clk) ;
@(posedge clk) ; sw_n = 1'b1;
@(posedge clk) ;
@(posedge clk) ;
@(posedge clk) $finish;
end
endmodule
The problem i am running is that the counter is increments after every two cycle of clock period instead after first period.
Here is the snapshot from Model Sim,
update: 12/20/2018
Edited code:
always @(sw_n, current_state) begin
S0: begin
if (~sw_n) begin
next_state <= S1;
led_out <= S0;
end
else begin
next_state <= S0;
led_out <= S0;
end
end
is technically correct, but a better solution would be to use auto-sensitivityalways @*
. That way if the reference signals every change, you don't have to remember to add/remove it from the sensitivity. Separately, it is recommended use blocking assignment (=
) for combiantional logic. Non-blocking assignment (<=
) should be used with assigning synchronous logic. \$\endgroup\$
