I'm trying to solve, for the voltage across the capacitor in the following circuit:
The initial current in this circuit is equal to \$\text{I}_0\$. How can I find the voltage across the capacitor?
EDIT: The initial applied current is equal to \$\text{I}_0\$, the initial voltage across the capacitor is equal to \$\text{V}_\text{C}\left(0\right)\$ and the initial current trough the inductor is equal to \$\text{I}_\text{L}\left(0\right)\$
My Work:
I thought that I can write:
$$\text{V}_{\text{R}_1}\left(t\right)+\text{V}_{\text{R}_2}\left(t\right)+\text{V}_\text{C}\left(t\right)+\text{V}_\text{L}\left(t\right)=0\tag1$$
Writing that in terms of the current through the components I get:
$$\text{I}_\text{in}'\left(t\right)\cdot\text{R}_1+\text{I}_\text{in}'\left(t\right)\cdot\text{R}_2+\text{I}_\text{in}\left(t\right)\cdot\frac{1}{\text{C}}+\text{I}_\text{in}''\left(t\right)\cdot\text{L}=0\tag2$$
And then using the initial conditions \$\text{I}_\text{in}\left(0\right)=\text{I}_0\$ and \$\text{I}_\text{in}'\left(0\right)=0\$ I can solve for the voltage across the capacitor. Is that right?
| improve this question | | | | |
  • \$\begingroup\$ Is current \$I_0\$ supplied from a current source and was the current through the inductor prior to t=0 zero amps AND, was the voltage across the capacitor 0 volts at t=0? In other words you need to clearly state your initial condictions. At the moment there is ambiguity. \$\endgroup\$ – Andy aka Dec 20 '18 at 18:46
  • \$\begingroup\$ @Andyaka Yes only the intial current was supplied. \$\endgroup\$ – Klopjas Dec 20 '18 at 18:47
  • \$\begingroup\$ That does not answer what I asked. \$\endgroup\$ – Andy aka Dec 20 '18 at 18:49
    \$\begingroup\$ @Klopjas You must have the initial conditions for the state of the capacitor and the inductor. Given only the value of \$I_0\$ I believe there is more than one possible pairing of initial conditions for the capacitor and inductor. \$\endgroup\$ – jonk Dec 20 '18 at 18:51
    \$\begingroup\$ @Klopjas then all that remains for you to clarify is the source of that external current because that source type dictates what happens after t=0. \$\endgroup\$ – Andy aka Dec 20 '18 at 18:53
