I bought a liquid filling machine -http://a.co/d/8FMFWIU. There is a centrifugal pump model Dp 521 2Amps 12Volt. I want to replace this pump with a peristaltic pump. The pump is controller by a micro controller.
The pumps that i find are rated as 12volt / 1.4Amps.
Will the difference in amps cause an issue? I am guessing the system will run slower and the new pump should only draw the current(max 1.4a) that it needs and i shouldnt run into an overheating issue. am i correct?
No problem.
If the machine can provide 2A at 12V, then it can also supply lower currents, e.g. 1.4A. There will be no over heating issue.
By clicking "Post Your Answer", you agree to our terms of service, privacy policy and cookie policy
