I’m trying to calculate the average power dissipated as the heat in the resistor.
A 12 V amplitude sinusoidal signal is applied across a 500 ohm resistor.
I have determined the current amplitude to be 0.024 A and the root mean square to be 16.97 mA.
I use P = I x V = 0.024 x 12 = 0.288 W
Where P is the power, I is the current and V is the voltage.
Is this correct ?
  • \$\begingroup\$ No. You need to multiply RMS values of both current and voltage. \$\endgroup\$ – Eugene Sh. Dec 21 '18 at 18:12
  • \$\begingroup\$ So it should be 0.144 W ? \$\endgroup\$ – Dan Khan Dec 21 '18 at 18:13
    \$\begingroup\$ "12V amplitude" - is that 12Vrms, peak, or peak-peak? \$\endgroup\$ – Reinderien Dec 21 '18 at 18:27
    \$\begingroup\$ @Reinderien - or average (mean )? \$\endgroup\$ – WhatRoughBeast Dec 21 '18 at 18:41
    \$\begingroup\$ @WhatRoughBeast unlikely. Since there is no mention of a DC rail, the mean would be 0. \$\endgroup\$ – Reinderien Dec 21 '18 at 18:44
With AC the real power is
(From: https://en.wikipedia.org/wiki/Electric_power#Alternating_current)
Cosθ is 1 because you have resisitive load.
Thus you have to calculate with RMS values.
Note that power can also be calculated as
(From: https://en.wikipedia.org/wiki/Electric_power#Resistive_circuits)
and RMS voltage is
RMS voltage
(From: https://en.wikipedia.org/wiki/Root_mean_square)
Thus your power is enter image description here
By clicking "Post Your Answer", you agree to our terms of service, privacy policy and cookie policy
