For my power electronics course, I need to design a basic boost converter that is converting 5 V to 12 V with 0.5 A output current. Below you can see the simulation results. MOSFET is driven by 20 kHz 0.58 duty 5 V square waves. And rest is as it is seen.
I use IRF510 as switch, 1 mH inductor, 220 uF 25V cap. and 25 Ohm load. However when I attempt to the experiment I stuck around 3-4 V output voltage with IL of 200 mA. When I change the load to 1 kOhm I get the output voltage as I desire, yet the current drawn drops to around ~10-15 milliamp as you might guess.
At the bottom you can also see the driving pwm output that is generated by NE555.
Solution: Problem was using a resistor-like inductor, I tried using a coil inductance (1mH) and got the desired result. Resistor-like inductors get saturated after few 100 milliamps, so be careful checking that.
boost sim pwm output
    \$\begingroup\$ I'm not sure what your question is. Is that your experimental results don't match your spice simulation? \$\endgroup\$ – sstobbe Dec 22 '18 at 19:20
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
