I've Googled but didn't find an answer. Is it problematic to extend load cell wires? I would like to have the 4 cells under the 4 corners of something (since the object rests on those 4 corners), but we are talking about 2 meters by 2 meters. I can put the electronics in the center but want to put a load cell under each corner.
It's for this load cell:
https://www.sparkfun.com/products/10245
Do I risk getting losses over that distance (approx 1.4 meters) that could render it useless?
Thanks
  • \$\begingroup\$ I suggest twisted pairs or STP wire to reduce susceptibility to noise. with shld connected to combiner board only. Is it serviceable underneath? I might not put it there. \$\endgroup\$ Dec 22, 2018 at 22:26
  • \$\begingroup\$ No problem getting access there. Perfectly serviceable. \$\endgroup\$
    – Joris
    Dec 22, 2018 at 22:32
Given that load cells are driven using a current source and read as a voltage, extending the drive wires (within reason) will not cause a reduction in current and extending the sense wires will not cause a reduction in voltage. so it should be fine to extend the wires.
