-1
I’ve read in another article, that you can have low current and high voltage simply by having a resistor in your circuit. From what I understand, current is the flow of electrons and voltage is the energy is how much energy is transferred per unit charge. I think the current comes from energy that moves the electrons - kinetic energy(?). Now if we add a resistor which slows down the current, then the electrons will lose energy and therefore voltage will drop too since V=E/Q. This doesn’t make much sense to me can someone explain what’s going on here?
  • \$\begingroup\$ google ohm's law \$\endgroup\$ – jsotola Dec 23 '18 at 6:39
    \$\begingroup\$ a resistor does not slow down the current ... it only reduces the amount of current \$\endgroup\$ – jsotola Dec 23 '18 at 6:42
  • \$\begingroup\$ WIth really good insulation you have no current leakage, just a static charge. \$\endgroup\$ – Sunnyskyguy EE75 Dec 23 '18 at 8:03
  • \$\begingroup\$ @jsotola, current is a flow of electrons, which is slowed down: \$ i=\frac{dq}{dt}\$ \$\endgroup\$ – Chu Dec 23 '18 at 8:07
    \$\begingroup\$ @Chu electrons travel at the same speed, but current is the amount of electrons going past a point in a given time - do you think that is what jstola means? \$\endgroup\$ – Solar Mike Dec 23 '18 at 9:14
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
