I have 3-phase utility mains power supply whose phase voltage is 220 V, 50 Hz.
I keep getting confused about various calculations of the 3-phase mains as follows:
  1. Formula for the line voltage.
  2. Formula for the Average and RMS outputs of 3-phase full bridge rectifier.
  3. If I use this output of the bridge rectifier as my DC Link voltage to feed a 3-phase full H-bridge and drive it with 3-phase sinusoidal PWM then what will be Average and RMS voltages of the resulting 3-phase sinusoids?
  • \$\begingroup\$ Regarding Q3. The average of a sine is zero. \$\endgroup\$ – Transistor Dec 27 '18 at 23:19
$$ V_{ph-ph} = \sqrt 3 V_{ph-n} $$
  1. Formula for the Average and RMS outputs of 3-phase full bridge rectifier.
$$ V_a = \frac {3 \sqrt 3}{\pi}V_m = 1.654 V_m $$
where \$ V_m \$ is the peak phase to neutral voltage.
$$ V_{rms} = 1.655 V_m $$
which is very close to the average value.
The tutorial paper by Dublin Institute of Technology - Three-phase rectifier looks like it should be of considerable help to you.
  1. If I use this output of the bridge rectifier as my DC Link voltage to feed a 3-phase full H-bridge and drive it with 3-phase sinusoidal PWM then what will be Average and RMS voltages of the resulting 3-phase sinusoids?
Average of a sine is zero.
Ignoring losses the maximum phase to phase output voltage is the DC-link voltage. That will be your peak AC so the RMS value of your output voltage will be \$ \frac {1}{\sqrt 2}V_{DC} \$. (The RMS value of a sine is \$ \frac {1}{\sqrt 2}V_{pk} \$.)
| improve this answer | |
  • \$\begingroup\$ I tried to work out the above formulas to get DC link voltage which is 600 V for a 3-phase mains whose phase voltage is 200 V.. but i only get approx. 515 V. Why is this difference in the calculations? \$\endgroup\$ – scico111 Dec 28 '18 at 9:30
  • \$\begingroup\$ Add your calculations into your question as an update and we'll have a look. \$\endgroup\$ – Transistor Dec 28 '18 at 15:18
