I made this schematic using Ni multisim and I got asked to find the ‘gain of this circuit using a 1v p-p 1kHz sine signal’ and I was unsure about this because I’m not sure if it means voltage gain or current gain. Anyways I put the desired signal in, but the waveform is the exact same as shown below and I don’t see some type of gain. I just need to know the gain of this circuit and whether this waveform is correct. Thanks in advance ~Neamus
Emmiter follower oscilliscope
    \$\begingroup\$ The emitter-follower (input to base, output at emitter, collector tied to some source) will have a voltage gain very close to 1 (but just slightly less.) It definitely can provide added current compliance, though. (But I don't imagine the question was about that. You are in a better position to guess on that.) \$\endgroup\$ – jonk Dec 28 '18 at 18:32
  • \$\begingroup\$ I'm not sure this and I'm not sure that Well, educate yourself and be sure. Even if you have a wrong opinion then I would respect you more than when you have no opinion. So you think this circuit has to have gain, why? What type of circuit is it? A common...? And do those have voltage gain? \$\endgroup\$ – Bimpelrekkie Dec 28 '18 at 21:56
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
