I'm helping a friend by attempting to repair this display PCB. It uses 24vac input and he accidentally hooked it up to 120vac.
I am trying to identify the two components in this picture under the burn marks. I'm pretty sure they are diodes but am looking for more specifics so that I can order replacements. Anyone able to direct me anywhere or know anything about the two components labeled MX 21A.
    \$\begingroup\$ My guess is way more then those are damaged if you hooked it into 120v \$\endgroup\$
    – MadHatter
    Dec 28 '18 at 19:09
  • \$\begingroup\$ These were my thoughts exactly...but I told my friend I would try replacing those and see what happens. \$\endgroup\$
    – stevo
    Dec 28 '18 at 19:14
  • \$\begingroup\$ There's several small traces running in between those diodes that got vaporized. The burnt spot might also have become partly conductive and need cutting a gap. If it's a multilayer board that'll get messy quick. \$\endgroup\$ Dec 28 '18 at 19:53
  • \$\begingroup\$ Thanks for the heads up, I'l look out for this and check it out with my multimeter \$\endgroup\$
    – stevo
    Jan 4 '19 at 3:14
MX is an SMD Code for TI's TVS protection diode that may withstand 48V
SMBJ48A The left side, DS1 vaporized some material.
