I am using Altium Designer 17. My schematics is Hierarchical and divided into multiple sheets.
Few sheets have microprocessor stuff and other schematics have sensors in it. I have to connect sensor's pins to GPIO pins of the processor.
Sheets in which GPIOs are taken out from schematics symbol of the processor uses conventions like GPIO_PIN_180 as Net Labels and sheets which have sensors uses names corresponding to the functions of that pin as Net Labels (For example, ACC_INT is a interrupt pin of accelerometer).
Now, I want to connect two different net labels but they give me warning/error like Nets with Multiple names. I know how to disable that warning or error but I don't want to disable it as it helped us in the past to find few bugs. I want to know Industry standard to handle such situations to make my schematics readable and acceptable to other experienced designers. enter image description here
    \$\begingroup\$ You need to think seriously about why you're assigning two different names to the net in the first place. What does this actually accomplish for you? \$\endgroup\$
    – Dave Tweed
    Dec 29 '18 at 12:26
  • \$\begingroup\$ Few sheets which are at microprocessor hierarchy uses names for GPIO corresponding to the pin numbers. However, sheets having sensors requires names corresponding to their functions as it makes them more readable. I am planning to make one sheet which will tie two different net labels together. \$\endgroup\$
    – abhiarora
    Dec 29 '18 at 12:33
    \$\begingroup\$ Yes, you said all of that in the question. I repeat: What does this actually accomplish for you? Why not carry the sensor signal names all of the way to the pins of the microprocessor? Those are the names that are most relevant to your actual application. \$\endgroup\$
    – Dave Tweed
    Dec 29 '18 at 12:35
  • \$\begingroup\$ To make sheets reusable and independent of other sheets. I can implement what you have suggested if there isn't any other way to properly implement it? \$\endgroup\$
    – abhiarora
    Dec 29 '18 at 12:39
    \$\begingroup\$ In that case, reusable sheets need to be hierarchical sheets. Does Altium throw an error if you connect a net with one name to a hierarchical sheet port with a different name? I've never used Altium myself, but this worked fine in other software I've used. \$\endgroup\$
    – Dave Tweed
    Dec 29 '18 at 12:45
The only way I know is a net-tie. For example to connect Power_GND with Ana_GND in a defined way.
