Hi,
I'm just wondering about the current rating of the JST-XH and JST-VH connectors PER pin. For example, in the XH connector above, **
  • it says 3A current rating, is that split between all pins or does that mean one pin can carry 3A?
So in essence, if I dedicate two pins to VCC, then I could achieve 6A?
Yes it's per pin, however I think you're talking about paralleling contacts to double the capacity.
The current will be more likely to share more-or-less evenly if your wires are at least 1ft (30cm) long (and at least roughly matched in length). That's 16m\$\Omega\$ for the AWG22 wire vs the 10-20m\$\Omega\$ contact resistance.
If you're anticipating possible high ambient temperatures, you might want to scale back the total current a bit to account for uneven sharing.
  • \$\begingroup\$ Thank you. Would it be better to parallel contacts or use twice the number of connectors? I guess it would depend on heat right? I'm assuming the PCB side of things wouldn't be so happy with that much power being concentrated at one connector. \$\endgroup\$ Jan 5, 2019 at 4:35
You may add currents per pin but the MAX ambient temp spec range reduces some unknown value due to increased self-heating.
E.g. 3A^2* 20 mOhm = 180mW so the pin contact temperature might rise 40'C but adjacent pin temp somewhat less.
They mean per-pin. Note that you must use 22ga. wire (largest size this takes) to get the highest current rating.
