Hello everyone this is my first time posting here so forgive me if my post seems a little choppy. So my dilemma is trying to hook up a 2 pole three-phase DB motor rated at 230 X 3. I did a fair amount of research and thought I had the situation figured out until I got the motor disconnected from the machine and took the plate off of the junction box that is mounted to the motor and come to find 2 sets of wires each one with 1 blue, 1 red and 1 black. And another set that is wired into a brake rectifier.
Now I do have a couple questions. First do I need the brake rectifier wired in if I'm using a VFD or do I need it at all in order for the motor to run?
Also after doing a lot of reading and watching I thought I'd find 9 wires (there are 9 but the brake rectifier is throwing me off) with a diagram (no diagram) telling me which wires are what and then I'd be able to wire it up either y or delta.
Thank you.
