In Qsys, the address space is byte addressable. However, the datawidth of the master shall most likely be more than a byte. This could create a situation where sometimes a peripheral has wider data width than the master and at other times, a narrower data width than the master. I am sure that this complicates read and write accesses. e.g What if I want to read bytes in loop from a slave that has 16 bit data bus using a Nios that has a 32 bit data bus?
  1. Why doesn't Qsys use a fixed 32 or 64 bit data bus for all the components?
  2. How exactly does it get around the mismatch by inserting extra logic?
  • \$\begingroup\$ You can't e.g. UART has 8 bits data. There is no way to make that 32 bits. \$\endgroup\$ – Oldfart Dec 30 '18 at 10:24
