I came across an old development board with an ATMEL ATMEGA8A-PU . I am not an expert but I want to use this board. But something is missing in this board as seen in this photo:
ATMEL development board with a missing part
closed as unclear what you're asking by Nick Alexeev Dec 30 '18 at 21:22
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Schematic is missing. \$\endgroup\$ – Nick Alexeev Dec 30 '18 at 21:21
11
It is max232 ic.
Which is used to convert the signals from the RS232 serial port to the proper signal which are used in the TTL compatible digital logic circuits.
    \$\begingroup\$ Yes, one can even see "MAX" on the silkscreen in the hole in the socket. \$\endgroup\$ – Unimportant Dec 30 '18 at 8:56
  • 5
    \$\begingroup\$ To add: The board should work without it, you only need it if you want to communicate over the RS232. \$\endgroup\$ – Michael Dec 30 '18 at 12:44
    \$\begingroup\$ yes.. Michael is right... \$\endgroup\$ – Satish Singupuram Dec 30 '18 at 12:45
