I bought a ryobi kit in the us and I want to use it in in Europe.
I doubt that I can plug it directly into the socket, what kind of converter/adapter do I need?
Is there a way to adapt the charger itself?
closed as off-topic by Transistor, Matt Young, Leon Heller, brhans, duskwuff Dec 30 '18 at 20:47
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Transistor, Matt Young, Leon Heller, brhans, duskwuff
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Does it not say what input voltage range it accepts on the tag? Many SMPS these days accept all voltages between approx. 100 and 240V. \$\endgroup\$ – Unimportant Dec 30 '18 at 16:14
  • \$\begingroup\$ @Unimportant it says 120 volt \$\endgroup\$ – SamuelManuel Dec 30 '18 at 16:44
Two options,
one: get a 220v to 110v transformer (usually large yellow things),
Two, purchase a Ryobi charger in EU that matches the batteries.
  • \$\begingroup\$ sorry, added to question before I saw your answer \$\endgroup\$ – SamuelManuel Dec 30 '18 at 16:13
Just buy an off-the-shelf transformer to step down the voltage. Make sure the wattage is not less than the wattage of the battery charger. Smaller ones can even come with the correct US socket.
