I'm reading this article about stability of OpAmps: Link to article.
It says: "If Aβ is less than unity at the high frequencies where phase shift reaches 180°, the high-frequency phase-shifted signals will gradually fade away instead of progressively building up into major oscillations." This is depicted in the picture below.
However, I don't understand this. Shouldn't the system also be unstable at a loop gain less than 1? The 180 degree phase shift in the loop plus the subtraction at the summing point results in positive feedback (See figure 2 below). This means that when a signal is fed into the system (at the control input) it will be attenuated by the loop gain and the phase will be shifted 180 degrees before it arrives back at the summing point. The control signal is still present at the plus input of the summing point so the two signals will be added up resulting in a greater signal than before. When the system keeps doing this the amplitude of the signal will rise to infinity and thus the system will also behave unstable.
My question: Is there an error in my analysis? Why is it that the system is stable at a loop gain < 1 and a phase shift of 180 degrees?
