I'm trying to make a counter that counts: 0,1,2,3,4,5
I need this for a frequency divider of 6
So I made this table:
From this I get:
J0= 1
K0= 1
J1 = NOT Q0 AND Q1
K1 = Q1
J2 = Q1 AND Q2
K2 = Q1
I made the circuit in the software:
It does compile with 1 warning:
And when simulating only the first jkff is working:
Thank you
Suppose the output of FF 64 is 0. Then the output of AND2 must be 0, no matter the other input value.
Now the J input of FF 64 is 0. With J at 0, the output can never become 1.
Your logic for J1 is not implementing line 2 of your transition table correctly.
  • \$\begingroup\$ You mean the equation for J1 is not ok?I checked multiple time and it should be ok.... \$\endgroup\$ – Fox Alex Dec 31 '18 at 20:25
  • \$\begingroup\$ @FoxAlex, Your transition table says J1 should be 1 for Q[2:0] = 001. Your logic gives an output of 0 for this input. \$\endgroup\$ – The Photon Dec 31 '18 at 20:31
  • \$\begingroup\$ You are right, but why?I used this to calculate the equations and also done by hand and it should be good imgur.com/a/utDY3mB @ThePhoton \$\endgroup\$ – Fox Alex Dec 31 '18 at 20:41
  • \$\begingroup\$ @FoxAlex, I don't know how you mapped Q[2:0] to A, B, and C in the K-map, but it looks like you put a 0 in the 001 location instead of a 1, and you put the 1 in the 010 location. \$\endgroup\$ – The Photon Dec 31 '18 at 20:48
  • \$\begingroup\$ You are right, I didn't put the values in the right order in the map, can't believe, I looked at it so many times, thank you. \$\endgroup\$ – Fox Alex Dec 31 '18 at 20:58
