I'm looking for a way to solve the following circuit
Voltage in a delta circuit
Without the voltage sources on the circuit, I would be using a simple Y-Δ transform. But I'm not sure how I should proceed with them on.
Which methods should I use ?
  • \$\begingroup\$ Without the voltage sources you didn't need to do anything because there were no voltages and currents. \$\endgroup\$ – Curd Jan 1 '19 at 20:06
  • \$\begingroup\$ This circuit isn't large enough that any of the traditional approaches will work, pick between node-voltage, mesh-current, full Kirchoff's and then solve the simultaneous linear equations. Or simplify using Thevenin/Norton equivalence and reduce the resulting parallel sources and resistors. \$\endgroup\$ – Ben Voigt Jan 1 '19 at 20:10
There is a quite simple way to solve this (without Y-Δ-transform). Here is an outline:
Recognize that nodes A and B are connected by 3 parallel Thevenin sources (= voltage source with resistor in series).
Convert each of the Thevenin sources into a Norton source.
Those 3 Norton sources can be combined very easily into one Norton source.
If you want, you can transform that combined Norton source back into a Thevenin source.
Done.
| improve this answer | |
