-2
This question is an exact duplicate of:
Can anyoe teach me how to convert this into light activated switch (https://i.stack.imgur.com/r6lZH.jpg)
marked as duplicate by Chris Stratton, Dave Tweed Jan 2 at 18:57
This question was marked as an exact duplicate of an existing question.
Switch the LDR and 4.7K resistor.
  • \$\begingroup\$ Is that all? Thank you sir :) \$\endgroup\$ – Delion Jan 2 at 6:37
  • \$\begingroup\$ Sir 4.7k or 47k? And which one? \$\endgroup\$ – Delion Jan 2 at 6:42
  • \$\begingroup\$ 4k7 means a 4.7k resistor. \$\endgroup\$ – Gonzik007 Jan 2 at 18:14
Pin 6 is floating.. connect pin 6 with pin 2. (By doing so you are connecting inverting and non-inverting comparator together.
and change the 4.7K resistor with 1M ohm variable resistor .
Slowly change the resistance and adjust the sensitivity based on your ambient light.
