Along with my z80 development board I found a 16166 16*1 display.
I have found datasheets for the electronics, it have 8 data (but can be run in 4 bit also) and 3 control, but I have failed to find any actual programming manual.
Can anybody help?
    \$\begingroup\$ Is there a controller chip on the display? You might be able to find a data sheet for the controller. \$\endgroup\$ – Peter Karlsen Jan 2 '19 at 9:30
It is probably this display: MDL-16166-SS-LV with HD44780 compatible controller.
  • \$\begingroup\$ It takes a lot of pins; at least 4 data and 3 control. The easiest way if I need pins for other I/O is probably to give the display its own ESP8266 and just send text to it over mqtt, which I'm already using ;-) \$\endgroup\$ – Lenne Jan 2 '19 at 19:26
  • \$\begingroup\$ Oh well, there is a library for this: arduino.cc/en/Tutorial/LiquidCrystalDisplay I can get away with only 6 pins. \$\endgroup\$ – Lenne Jan 2 '19 at 20:17
