There seems to be an incoherence between what I see with my oscilloscope, and what I see with my spectrum analyser.
I have a signal of about 1MHz (if I'm not wrong), 5mV, from an antenna, through RG174 coaxial. It is clearly seen in the following picture of my oscilloscope screen.
Then I connect the same cable to my spectrum analyser, and see nothing like this apparently (see next picture).
Is my spectrum analyser damaged, or am I missing some point ?
Additional information:
OSCILLOSCOPE: AC, 50 ohm, 1ns/div, 5mv/div
SPECTRUM: 50 ohm, start frequency 500kHZ, stop frequency 15MHz, ref level 1mV, attenuation 0db, 10 db/div, set in average mode for clarity, but the same problem subsist in non average mode.
    \$\begingroup\$ 1ns/div, and a bit more then 1 division top to top on the waveform, isn't that nearly a GHz? \$\endgroup\$ Jan 2, 2019 at 12:06
  • \$\begingroup\$ @Unimportant is right, 1.2ns =~ 833Mhz \$\endgroup\$
    – Damien
    Jan 2, 2019 at 12:12
  • \$\begingroup\$ All of these types of questions should have the instrument's model numbers listed \$\endgroup\$
    – pipe
    Jan 2, 2019 at 13:17
Your oscilloscope shows an oscillation with a frequency in the \$\frac{1}{1\,\text{ns}}=1\,\text{GHz}\$ range. (So, yes, you're wrong, that's not a 1 MHz oscillation. I'm jealous of your oscilloscope, by the way.)
Your spectrum analyzer is set to cover 400 kHz to 15.14 MHz. You can't see a GHz oscillation in that range.
  • \$\begingroup\$ Oh I am stupid ! \$\endgroup\$
    – MikeTeX
    Jan 2, 2019 at 12:19
    \$\begingroup\$ no, you're (probably) not, mistakes just happen! \$\endgroup\$ Jan 2, 2019 at 12:20
