Im interested in how watt per kg has advanced over the past 10-20 years for consumer solar panels. Can anyone shed some light on this? A table would be great.
    \$\begingroup\$ Are you certain you want to go by mass? If you want to do so you need to define whether you are counting just the cell or also the substrate or also the coating or also the required wiring, or also the plexiglass cover, etc. If you want to go entirely by weight, you likely should read up on thin film panels as arguably they have the highest durability*power output because of how much less it takes to protect them, as they cannot shatter. There is also huge variance in wattage per square foot, and also multiple upcoming technologies like possible solar paint. \$\endgroup\$
    – K H
    Jan 4, 2019 at 5:43
  • \$\begingroup\$ Will you be including the mass of all supporting framework in the total mass? \$\endgroup\$
    – Solar Mike
    Jan 4, 2019 at 6:35
  • \$\begingroup\$ Panels are normally rated by kWp, so if you take that and the size ie area of the panel that may be a start, but you will also need to factor in things like the cell technology and the location. \$\endgroup\$
    – Solar Mike
    Jan 4, 2019 at 7:52
Yes, it has improved quite a bit.
Power per mass is quite an odd way to look at it, unless you are sending stuff in the air, space or carry around in a bike or something similar.
Although as the power per weight is linked to the power efficiency as the weight of solar panels hasn't changed much over time.
On a cell level, efficiencies have greatly improved, you can see at the graph below, they are "research cell samples" so it won't be applicable to common panels but it gives an idea of the improvements.
enter image description here Source
If you take a normal panels, new mainstream technologies such as bifacial, N-type cells, back-contact and Hetero-junction together with process improvements have improved the power output of the panel (and related to its mass given the panel remains the same).
The new Shingle Technology, now being implemented by many manufacturers will hit the market in 2019 and these packs the module area with more cell density, so this will also be a step to increased power per panel (and thus power/weight ratio of a standard panel).
If you really care about weight, there are thinfilm panels laminated on plastic films, which have lower power density per m2 but higher power density per kg as they are very light and not using glass, which is the main contribution to the panel weight.
For space, usually it is used multi-junction solar cell, directly glued on an aluminium honeycomb substrate and they are not protected / encapsulated as they go in space. Those provide the highest power / area / weight but also are very expensive.
What is important to note, is that the cost per kW has significantly decreased and is expected to keep decreasing. It is now often cheaper (depending the country and irradiation) to produce energy by solar than coal / gas / nuclear. Those remains cheaper on the bill, because of massive government subsidies and past investment, especially in gas and nuclear which makes it an uneven market.
The most comprehensive survey of cell efficiency from research is available at NREL of which the below graph (similar but more recent than the the one from Damien) can be found:
While W/kg is one metric, it should be noted that all those efficiency discussions are based on AM1.5 considerations which while being useful for comparing efficiencies overlooks the heating of solar panel in low latitude at times of peak solar energy.
Depending on your needs (outdoor energy, off-grid or grid feed-in, indoor energy (solar calculator and small wireless sensor ondes), ...) you should carefully consider which technology you want to use as new technologies such as DSSC, perovskite, organic will yield more indoor than silicon based ones which fair better outdoors. For outdoors cristalline yield the pack, but again if you own the system from end to end you should look carefully at your use case: * do you need to optimise for peak power production or do you need to optimise total power production - in other words do you need to produce energy at low sun elevation or do you need to maximise power production at high sun elevation
