In a new circuit design, I need some impedance matching for some high speed traces (i.e. Ethernet, USB, SD card...). Usually I define tracks width with this web tool https://www.eeweb.com/tools/microstrip-impedance
Now for the first time I have to use a 4-layer board and I would like the traces in one of the 2 internal layers (so I can better shield these signals). Which one of the types of microstrip should I choose? (Embedded Microstrip, Asymmetric Stripline...?)
And also, since there will be other traces to match that are close to each other, will they influence each other?
Thank you very much.
With 4 layers, you can make microstrip, embedded microstrip, or asymmetric stripline. Use whichever one suits your needs the best.
Outer layer microstrip will probably use the least board area for a given set of interconnections.
Asymmetric stripline will provide the best shielding, but remember you will need unbroken ground planes both above and below the track, which will restrict how you can route other lines.
A usual rule of thumb is to make sure uncoupled tracks are placed at least 10x the track width away from each other.
If you mean the coupled track in a differential pair, you should use the edge-coupled microstrip or edge-coupled stripline (your calculator doesn't seem to support asymmetric edge-coupled stripline, so you'll need to find a new calculator) to calculate the geometry for your differential pairs.
  • \$\begingroup\$ Thank you very much for your clear answer. Regarding uncoupled tracks, what could happen in the distance is not 10x but, for example, is only 3x? I suppose there will be a problem related to a different Impedance of the conductor and also a crosstalk problem, right? \$\endgroup\$
    – MatD
    Jan 7, 2019 at 8:43
