Ok, time for idealized opamp rules.
- No current into opamp inputs
So, all current that flows through R1 also has to flow through R2.
(derivative rule) An opamp in negative feedback will coerce its inputs to take 0V difference.
That means V⁻ will be 0V (GND potential).
From that follows that the right hand side of R2 (where the other resistors attach) is at - (Vin/2), since R1 = 2 R2 (and the same current flows through both).
Since the voltage across R3 is \$V_\text{node}=-\frac12 V_\text{in}\$, the current through R3 is
$$I_3 = \frac{-\frac12 V_\text{in}}{\mathrm R3}\text,$$
which leaves us with
\begin{align}
I_4 &= I_\text{in} - I_3\\
&= \frac{V_\text{in}}{\mathrm R1} - \frac{-\frac12 V_\text{in}}{\mathrm R3}\\
&=V_\text{in}\left(\frac1{\mathrm R1}+\frac1{2\mathrm R3}\right)
\end{align}
to flow through R4.
That yields an output voltage of
\begin{align}
V_\text{out} &= V_\text{node} + I_4\cdot \mathrm R_4\\
&=V_\text{node} +V_\text{in}\left(\frac1{\mathrm R1}+\frac1{2\mathrm R3}\right)\cdot \mathrm R_4\\
&= -\frac12 V_\text{in} +V_\text{in}\left(\frac1{\mathrm R1}+\frac1{2\mathrm R3}\right)\cdot \mathrm R_4\\
&= V_\text{in}\left(\frac{\mathrm R4}{\mathrm R1}+\frac{\mathrm R4}{2\mathrm R3} - \frac12\right)\text.
\end{align}
The gain is hence
\begin{align}
\frac{V_\text{out}}{V_\text{in}} &= \frac{\mathrm R4}{\mathrm R1}+\frac{\mathrm R4}{2\mathrm R3} - \frac12 \\
&\overset != -120\\
-119.5 &= \mathrm R4\left(\frac{1}{\mathrm R1}+\frac{1}{2\mathrm R3}\right)
\end{align}
I must admit I can't find a non-negative solution for R4, so I must've gone wrong somewhere.
