-2
I'm on internship in one of the embedded solutions company. They gave me a task to interface esp8266 12E module with nuvoton m058ldn. I could not able to find any document in internet but i saw one clue that in nuvoton datasheet there mentioned that it can be interface with esp8266. But i have no idea how to proceed. So please help me i'm a beginner.
closed as too broad by laptop2d, Dwayne Reid, Anindo Ghosh, Elliot Alderson, pipe Jan 8 at 14:33
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ interfacing wifi module ESP8266 with nuvoton Mo58ldn and need to send the data to the server through wifi \$\endgroup\$ – Manu Devappa Jan 5 at 16:08
  • \$\begingroup\$ Yes, but which module? \$\endgroup\$ – Long Pham Jan 5 at 16:09
  • \$\begingroup\$ Sorry sir i'm little confused!! like how you asking me about module ? i hope esp8266 is wifi module which i used to interface with arduino. and the same module need to interface with nuvoton m058ldn. is it possible to do so ? \$\endgroup\$ – Manu Devappa Jan 5 at 16:11
    \$\begingroup\$ Yes its possible, think about how you hooked up the arduino, and look for the same comms on the new chip...connect it. also take into account voltages. you may need a level shifter \$\endgroup\$ – jsolarski Jan 5 at 16:42
  • \$\begingroup\$ thank you sir ! \$\endgroup\$ – Manu Devappa Jan 6 at 10:28
