We have 230 VAC power supply in our lab.A chemical earthing is done for this power supply. I have connected a SMPS (LRS-35-12) to it. The Output of SMPS is connected to a load of maximum 2A. I have measured the smps output voltage as 12VDC and the device (load) is working and controller is sending data also. But at the same time I have turn my multi-meter at AC voltage mode and measured the SMPS output voltage,I found it as 25VAC. (I expected it to be around 0 VAC.)
So, what could be the reason of it?
  • \$\begingroup\$ What is "chemical earthing?" \$\endgroup\$ – JRE Jan 7 at 11:57
  • \$\begingroup\$ It is basically the GI earthing( Rod earthing). Only we have added salt and charcoal around the rod to improve the earth pit resistance. \$\endgroup\$ – Aakash Dey Jan 7 at 12:02
  • \$\begingroup\$ 25VAC across the SMPS outputs, or between the SMPS and earth? \$\endgroup\$ – JRE Jan 7 at 12:10
  • \$\begingroup\$ I am giving the details below: Voltage between Line and neutral= 228-238VAC. Voltage between Earth and neutral= 20-25 VAC. Voltage at SMPS Output= 12VDC Voltage at SMPS Output= 25VAC \$\endgroup\$ – Aakash Dey Jan 7 at 12:16
  • \$\begingroup\$ So, as we have earthing so a 20-25VAC between earth and neutral is unexpected. Also it is unexpected to have 25VAC at the SMPS output. \$\endgroup\$ – Aakash Dey Jan 7 at 12:23
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
