I use arbitrary waveform generator TGA12104 for generating sine wave with following parameters(voltage - up to 10 V, current - up to 0.2 A, frequency - up to 0.1 Hz (most often about 0.005-0.05 Hz).
However, maximal power from the waveform generator is small for needed purpose and I would like to gain the output signal from the generator.
Could you prompt are there any amplifier with tunable gain ratio (in range 1-15) and accurate preservation of sine wave current with the same (although very low) frequency? If so, where can we find it?
closed as off-topic by Vladimir Cravero, JRE, Elliot Alderson, Dwayne Reid, Finbarr Jan 8 at 16:21
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Asking for device recommendations is off topic here. Your question will probably be closed for that. \$\endgroup\$ – JRE Jan 7 at 12:18
  • \$\begingroup\$ maybe the amplifier found here can work? systems.polyamp.com/file-archive/documentations/… \$\endgroup\$ – Anton Ingemarson Jan 7 at 15:25
    \$\begingroup\$ What is the load on this amplifier? \$\endgroup\$ – The Photon Jan 7 at 16:10
    \$\begingroup\$ Almost any power opamp should do this job in a DC-coupled configuration. Something like OPA541 is gross overkill, but it will work. \$\endgroup\$ – henros Jan 7 at 16:51
  • \$\begingroup\$ You can use a commercially-available Audio Power Amp of appropriate power rating so long as it is DC coupled. Or: you can build something similar for yourself. This site will help you design such a device that you can build yourself but asking for product recommendations is strictly off-limits. \$\endgroup\$ – Dwayne Reid Jan 8 at 0:52
