I have been using the BSS138 level converter circuit for a while now and today it struck me I get how the voltage is stepped up by the FET or the BSS138 when you are applying say 3.3 V on the LV side.
What happens in the FET to reverse that and make it bidirectional?
Enter image description here
When the HV side goes low, the body diode becomes forward biased, pulling down the source to a lower voltage than the gate.
Provided the gate is pulled up to a sufficiently high voltage for that new source voltage to bias the channel into conduction, the gate pullup takes over and fully enhances the channel.
| improve this answer | |
  • \$\begingroup\$ Thanks that helps, but i feel stupid now I found the answer as soon as I posted: cdn.sparkfun.com/tutorialimages/BD-LogicLevelConverter/… that PDF has a great explanation on page 10 and 11 of what happens \$\endgroup\$ – Tjaart van aswegen Jan 7 '19 at 15:19
    \$\begingroup\$ Interestingly I once plotted the BSS138 characteristics in the reverse direction and the threshold was lower than in the forward direction (~0.4V in my case) so the body diode never even conducted in this application. \$\endgroup\$ – Kevin White Jan 7 '19 at 15:23
  • \$\begingroup\$ I came across this brain tease today at work when I looked at one of my PCB designs and realized that my Drain and Source pins was switched and that got me thinking what actually makes it work says a lot about my PCB design skills LOL \$\endgroup\$ – Tjaart van aswegen Jan 7 '19 at 15:27
When you apply 3.3V on the LV side the MOSFET turns off (Vgs ~=0) and the 10K resistor R4 pulls the drain up to 5V.
The only pull-up on either side is the 10K resistors so it can have relatively slow rise time compared to a voltage translator chip.
