This question already has an answer here:
I have a RL80-UR543 LED 8MM. How much voltage I need if I use a resistor of 100Ohm?
marked as duplicate by winny, awjlogan, DoxyLover, laptop2d, Blup1980 Jan 10 at 14:49
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
Forward Current (If) = 20 mA and
Forward Voltage (Vf) = 1.7V to 2.8V
is written on datasheet
  • maximum voltage = 20mA*100ohm + 2.8V = 4.8V
  • \$\begingroup\$ I conntect it to a battery without any resistor and nothing happened. Bettery is 1.5v \$\endgroup\$ – No Namer Jan 8 at 20:31
  • \$\begingroup\$ I calculated theoretical maximum voltage according to your requirements. Using leds without current control not a good way. \$\endgroup\$ – Koray Jan 9 at 5:56
