I know what it means to be edge or level triggered but considering the block diagram or logic diagram of inside of latches and flip flops I cannot see what inside them specifies this property of each, or how are they different that makes some level triggered and some edge triggered?
Can someone explain please?
The edge is performed by Transmission gate switches with positive feedback on the D value to isolate it by holding the charge voltage at D when Clock goes high to enable gate without o- and disable with -o using complementary drive switches with CMOS.
Ref
  • \$\begingroup\$ Hey, err...Sunnyskyguy?...could you please add a citation or other attribution for the graphic content you included in your answer? \$\endgroup\$ Jan 8, 2019 at 18:16
  • \$\begingroup\$ Ref link was in comments ehm.. \$\endgroup\$ Jan 8, 2019 at 18:19
