My circuit: enter image description here
Signal coupled in power supply (3.3V) of STM32F103 during spark:
Is there any benefit to using this diode (circled in red) or not (without this diode the snubber circuit will start working)?
What is a better solution/topology to avoid noise and maintain the spark efficiency?
My doubt is:
If I use this shown configuration, is it more difficult to cut-off the SCR (maintain hold current for a long period) and can it disturb another part in circuit?
I use an automotive sparkplug resistive cable with 4K ohms and a earth strap to connect the engine with ignition coil GND (frame).
The diode D4 is relevant during the C3 charging, is it a necessary solution or does it not make a big difference in this circuit?
  • \$\begingroup\$ How can we know if your probe ground length is picking up noise? You can show noise with probe on nearest ground \$\endgroup\$ – Sunnyskyguy EE75 Jan 8 at 18:57
  • \$\begingroup\$ To do this measure I put the osciloscope GND in the negative terminal of Battery and microcontroller VDD (3.3V), how should I have done? Thanks for your attention! \$\endgroup\$ – Fabio CRJ Jan 8 at 19:42
  • \$\begingroup\$ Directly across D5 electronics.stackexchange.com/questions/298657/… \$\endgroup\$ – Sunnyskyguy EE75 Jan 8 at 19:46
  • \$\begingroup\$ Move probe tip to same ground used by probe and see how big the glitch is. THis is measurement error. That's why it must be short to reduce loop AREA \$\endgroup\$ – Sunnyskyguy EE75 Jan 8 at 22:40
  • \$\begingroup\$ In this video: youtube.com/watch?v=kfKosUKUt-A , you can watch in channel 1 (referent D5 - anode of SCR) and channel 2 Microcontroller VDD. Diode circunded in red are present in circuit (connected)! \$\endgroup\$ – Fabio CRJ Jan 8 at 22:46
By clicking "Post Your Answer", you agree to our terms of service, privacy policy and cookie policy
