I'm trying to run my code on the new AT89LP52 chip which Microchip (A.k.a. Atmel) believes can be a direct replacement for the AT89S52.
I am able to program the AT89S52 with my programmer and software perfectly fine, and attempting to run that chip in the target board works perfectly fine as well. (Yes, I remove the chip from the programmer board to another board). Of course then I had two 33pF capacitors tied between the crystal connection points and ground.
So now, I tried the AT89S52. From observation, I'm able to write a large string of data (over 2KB) to the chip, I'm able to set fuse values, and I'm able to read a large string of data from the chip. but I can't seem to get it to execute code in the target board.
So I took the "may NOT need capacitors" line from the datasheet and removed the capacitors from my target board (since I'm always using a 22.1184Mhz crystal in the target board) and I tested again, and got no luck.
I'm starting to wonder if I'm injecting the data into the chip improperly. In the AT89S52, there is no half-page bit "s" but in AT89LP52, there is a half-page bit.
Here's pseudocode I use to program AT89S52 after its erased:
set count=0
For page starting with 0...
    Output 50h
    Output page
    For block = 0 to 255
        Output data_byte
        increment count
        if count > data length then end
    next block
next page
Here's pseudocode I use to program AT89LP52 after its erased:
set count=0
    Output 50h
    set mypage=page shifted left 6
    Output integer value of mypage divided by 256
    Output integer value of mypage mod 256
    For block = 0 to 63
        Output data_byte
        increment count
    next block
next page
Am I doing something wrong in programming the AT89LP52?
I added datasheet information to both microcontrollers for reference.
datasheets
Update
I made use of the status byte during programming and for each set of 64 bytes I sent to the new AT89LP52, the results were success each time.
My pseudo code for that....
Output 60h
Output 0h
Output 0h
read status
Logical "and" the status with value 5
if result isn't 5 then repeat
Programming time is a bit longer with this verification step added, but still I can send data to and read data from the chip.
So far, no success on getting the chip (AT89LP52) to run the code on the target board. The voltage supplied to the target board is 4.8V (5V USB power from my computer fed through an LM2940 regulator. Voltmeter measures 4.8V).
By clicking "Post Your Answer", you agree to our terms of service, privacy policy and cookie policy
