I'm looking for a small color screen, and I came across the Adafruit Mini Color TFT with Joystick FeatherWing. But I want it to be a bit smaller, and I don't need the joystick and buttons on it. Would it be safe, and if so, how would I take off the screen and use that separately?
closed as off-topic by Eugene Sh., Voltage Spike, Elliot Alderson, Chris Stratton, RoyC Jan 13 at 8:16
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – Eugene Sh., Voltage Spike, Elliot Alderson, Chris Stratton, RoyC
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ How much smaller do you want it? there's a version without the joystick. adafruit.com/product/3533 \$\endgroup\$ – Phil G Jan 10 at 19:15
I wouldn't recommend it. The display is soldered to the PCB with a somewhat fragile flexible cable. You may have a hard time detaching the display and desoldering the cable without damage.
If you want the bare display without the carrier board at all, you can source those directly. Search for "ST7735 160x80" on your favorite Chinese marketplace -- this controller is used with a range of displays, and the 80x160 color display used by Adafruit is among them.
If you want the display on a carrier board without the buttons or joystick, Adafruit sells that too.
