I need to make a 4x 4-20mA measuring circuit with ads1115 (VDD = 5V) 4 channel 16bit ADC
I set ads1115 PGA to 4.096 gain and set circuit as below. once I set this 32000 ADC levels--> 4.096V--> 0.128mV
I am targetting to archive 0.128mV resolution.
R1 50ohm and R2 200ohm voltage divider is for regulating 5v to 4v. also, I set R2 200 ohm to get 4V at 20mA current.
R3 3.3k Ohm is there for reducing current flow into ADC1115 chip.
this is for a 3 wire sensor (24V DC supply, 4-20mA output and gnd)
** is this circuit configuration a reliable method to measure 4-20mA current using an MCU? **
  • \$\begingroup\$ It's mostly OK but why do you think you need R3? Also I think you mean "... to measure 4 - 20 mA current using an MCU?" \$\endgroup\$
    – Transistor
    Jan 10 '19 at 19:10
  • \$\begingroup\$ I need to measure 4 - 20 mA current using an MCU, therefore I chose ads1115 (I2C) and above circuit \$\endgroup\$
    – iopertyki
    Jan 10 '19 at 19:22
  • \$\begingroup\$ That does not answer my question. \$\endgroup\$
    – Transistor
    Jan 10 '19 at 19:22
  • \$\begingroup\$ I set R3 3.3k to block any unnecessary current draw into ADC. I assume if any current small draw into ADC will reduce my voltage reading across the R2 200ohm \$\endgroup\$
    – iopertyki
    Jan 10 '19 at 19:25
  • \$\begingroup\$ Any current the ADC draws is necessary for it to take an accurate reading. It will, however, be very low. The datasheet will tell you what the input impedance is. \$\endgroup\$
    – Transistor
    Jan 10 '19 at 19:39
It looks like it will function. Whether it's "reliable" or not depends on the environment. It's not up to "professional" process control standards.
You should consider an anti-aliasing filter- Nyquist is approximately 125kHz for the ADS1115 (half the modulator frequency).
Some 4-20mA devices can output much more than 20mA in the case of exception situations such as sensor break or overrange. Above 25mA you will exceed Vcc of the ADC. At some point, damage might occur.
