I have a bunch of Darlington NPN Transistors TIP142 that are removed from two separate identical boards. The 1st one have the TO−218 CASE (left side of the image) and the 2nd the TO−247 CASE (right side of the image)
https://www.onsemi.com/pub/Collateral/TIP140-D.PDF
enter image description here enter image description here enter image description here
With the Diode Test when I measure the Base-Emiter with N-Probe to Base and P-Probe to Emmiter with the TO−247 I get about 1.368V for all of them, but the same measurement for the TO−218 is OL for all of them (Please note that the multimeter with no probes connected is also indicate OL).
The resistance between them is for the TO−247 about 3.56KOhm and for the TO−218 about 15KOhm.
The other measurements seems to be identical.
So I am really confused and I wonder if some of them are faulty.
Edit: In my opinion since there are two resistors in series between Base and Emitter there should be a voltage drop. In the TO-247 case my multimeters show OL maybe because there is no much current to draw to show any measurements. Note that the resistance in that case is about ~15KOhm instead of the 3.56Kohm of the TO-247. The datasheet referes that the 1st resistor is ~8K but for the 2nd just ~40 ???? what ?
Multimeter with probes not connected indication
    \$\begingroup\$ please take a clear image of TO-247 and upload it in question.. \$\endgroup\$ – Satish Singupuram Jan 10 at 20:17
  • \$\begingroup\$ The resistance measurements seem to indicate that the TO-218 versions have a higher base-emitter voltage -- are you sure you were reading zero, or was your meter out of range? Do you know what the diode voltage measurement range is on your meter? \$\endgroup\$ – TimWescott Jan 10 at 21:07
  • \$\begingroup\$ Measure the resistances in both directions (polarities) to see the effects of the base-emitter junctions. \$\endgroup\$ – AnalogKid Jan 10 at 22:12
  • \$\begingroup\$ @AnalogKid It does not matter. Its always the same. \$\endgroup\$ – Maverick Jan 11 at 7:13
  • \$\begingroup\$ @TimWescott the indication I get is .OL which is the same i get when is not connected (stand by). \$\endgroup\$ – Maverick Jan 11 at 7:14
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
