For a school project , I'm trying to design an 8-bit standard ALU in VHDL, With a twist. I want it to take the input in serial form but show the output in the parallel form. here is a code of mine :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.NUMERIC_STD.all;
---------- ALU 8-bit VHDL ---------------------
entity ALU is
  generic (
     constant N: natural := 1  -- number of shited or rotated bits
    Port (
    A, B     : in  STD_LOGIC_VECTOR(7 downto 0);  -- 2 inputs 8-bit
    ALU_Sel  : in  STD_LOGIC_VECTOR(3 downto 0);  -- 1 input 4-bit for
selecting function
    ALU_Out   : out  STD_LOGIC_VECTOR(7 downto 0); -- 1 output 8-bit
    Carryout : out std_logic        -- Carryout flag
end ALU;
architecture Behavioral of ALU is
signal ALU_Result : std_logic_vector (7 downto 0);
signal tmp: std_logic_vector (8 downto 0);
begin
   process(A,B,ALU_Sel)
 begin
  case(ALU_Sel) is
  when "0000" => -- Addition
   ALU_Result <= A + B ;
  when "0001" => -- Subtraction
   ALU_Result <= A - B ;
  when "0010" => -- Multiplication
   ALU_Result <= std_logic_vector(to_unsigned((to_integer(unsigned(A)) *
to_integer(unsigned(B))),8)) ;
  when "0011" => -- Division
   ALU_Result <= std_logic_vector(to_unsigned(to_integer(unsigned(A)) /
to_integer(unsigned(B)),8)) ;
  when "0100" => -- Logical shift left
   ALU_Result <= std_logic_vector(unsigned(A) sll N);
  when "0101" => -- Logical shift right
   ALU_Result <= std_logic_vector(unsigned(A) srl N);
  when "0110" => --  Rotate left
   ALU_Result <= std_logic_vector(unsigned(A) rol N);
  when "0111" => -- Rotate right
   ALU_Result <= std_logic_vector(unsigned(A) ror N);
  when "1000" => -- Logical and
   ALU_Result <= A and B;
  when "1001" => -- Logical or
   ALU_Result <= A or B;
  when "1010" => -- Logical xor
   ALU_Result <= A xor B;
  when "1011" => -- Logical nor
   ALU_Result <= A nor B;
  when "1100" => -- Logical nand
   ALU_Result <= A nand B;
  when "1101" => -- Logical xnor
   ALU_Result <= A xnor B;
  when "1110" => -- Greater comparison
   if(A>B) then
     ALU_Result <= x"01" ;
   else
    ALU_Result <= x"00" ;
   end if;
  when "1111" => -- Equal comparison
   if(A=B) then
   else
   end if;
  when others => ALU_Result <= A + B ;
  end case;
 end process;
 ALU_Out <= ALU_Result; -- ALU out
 tmp <= ('0' & A) + ('0' & B);
 Carryout <= tmp(8); -- Carryout flag
end Behavioral;
this code is parallel in parallel out. also I have the code for an SIPO to attach to the input of the ALU code in order to have it take serial input :
library IEEE;
 use IEEE.STD_LOGIC_ARITH.ALL;
entity SerinParout is
port(
CLKs : in std_logic;
CLKp : out std_logic;
RST  : in std_logic;
Serial1: in std_logic;
Parallel1 : out std_logic_vector(7 downto 0));
end SerinParout;
architecture Behavioral of SerinParout is
signal temp : std_logic_vector(6 downto 0);
signal counter: integer;
begin
 process(RST,CLKs)
 begin
  if RST='1' then
    temp<="0000000";
  counter<=0;
  CLKp <='0';
  else
     if(CLKs='1' and CLKs'event) then
       if (counter<7) then
            temp(counter)<=Serial1;
           CLKp <='0';
           counter<=counter+1;
       else
           Parallel1<=Serial1&temp;
           CLKp<='1';
           counter<=0;
       end if;
     end if;
 end if;
 end process;
end Behavioral;
my question is syntax wise what do I specifically change in the former code to have it feed of the latter therefore forming an ALU that is attached to a SIPO in the input forming an ALU that takes input in a serial form. thank you for your attention.
New contributor
Parsa is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
closed as too broad by Eugene Sh., Dave Tweed Jan 10 at 22:28
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Take a regular ALU and connect to to a SIPO register on the input. \$\endgroup\$ – Eugene Sh. Jan 10 at 22:23
    \$\begingroup\$ Or write a 1-bit ALU and stick a SIPO register on the output. \$\endgroup\$ – Wouter van Ooijen Jan 10 at 22:32
  • \$\begingroup\$ This is either a silly idea, or there's a big part you are leaving out. Realize that the majority of the time, at least one input of the ALU is a previous output, often quite recently so. So this would make no sense unless you were pairing the ALU with a register file or storage that had the same arrangement in reverse. \$\endgroup\$ – Chris Stratton Jan 10 at 22:54
    \$\begingroup\$ do you realize that you are asking how to design a serial to parallel converter? \$\endgroup\$ – jsotola Jan 10 at 23:31
    \$\begingroup\$ Your edit does not fix the problems with your question. EESE is not a code writing service. You need to make an actual attempt at the serial-parallel conversion yourself. This is obviously homework (as it's a nonsense task for any real project), and an inability to do that suggests you did not pay attention in previous class segments, so you'll need to review the previous class material. \$\endgroup\$ – Chris Stratton Jan 11 at 17:24
