Suppose I have a circuit with two ports. One port is considered the input, and the second port is considered the output.
Assume it's described via
$$V_{out} = \frac{V_{in}}{2}$$
Now assume there's no voltage applied to the input terminals.
Supply the output port with 5 V. If I measure the terminals of the input port, will I see 10 V?
In general, the answer is no, of course, as a voltage divider will show.
What do you call circuits that do satisfy the behavior where you measure 10 V at the input port given a supplied 5 V source at the output port? I'm asking for a general term, but using an example to illustrate what I mean.
    \$\begingroup\$ which behavior? .... you talked about two \$\endgroup\$ – jsotola Jan 11 at 1:46
  • \$\begingroup\$ Hmmm... Reversable? Bidirectional? Ambivalent? I move that we all use "Ambivalent voltage converter" from now on. Seriously though probably bidirectional. \$\endgroup\$ – K H Jan 11 at 2:19
  • \$\begingroup\$ @KH I like that term. It's intuitive, and simple. If you answer with this same comment, I'll accept it. \$\endgroup\$ – Metric Jan 11 at 2:32
  • \$\begingroup\$ We'll wait a while to see if one of the engineers pops in, as they could comment with greater certainty than I and there may be an existing accepted term. \$\endgroup\$ – K H Jan 11 at 2:44
  • \$\begingroup\$ You got it! I'm just trying to avoid one of those cases where a question has a good answer in the comments but never becomes an actual "answer" for years and years. \$\endgroup\$ – Metric Jan 11 at 2:46
  • In the specific case where \$V_\text{out}\$ and \$V_\text{in}\$ take on only two possible levels, the device is known as a bidirectional (logic) level translator/converter/shifter.
  • In the specific case where \$V_\text{out} = V_\text{in}\$, it is of course a wire or transmission line.
  • In the specific case where the device can be switched between \$V_\text{out} = V_\text{in}\$ and no connection, it is a switch — or, if implemented in semiconductors rather than mechanically, specifically an analog switch or transmission gate.
I do not expect there is a formal term for the general case of this behavior because it's not a realistic "found" behavior in a circuit except in special cases that are best considered on their own. That said, “bidirectional” would be a reasonable word to use — just don't expect it to automatically imply everything you've described here.
Hmmm... Reversible? Invertible? Bidirectional? Ambivalent? I move that we all use "Ambivalent voltage converter" from now on. Seriously though probably bidirectional.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
