I would like to calculate the reactive power of a given two-pole which has the following voltage and current characteristic.
\$u(t) = 2+5sin(\omega t)+2sin(2\omega t+\frac{\pi}{6});i(t) = 10+3cos(\omega t-\frac{\pi}{6})+8sin(3\omega t)\$
So I know the reactive power is calculated by one the following formulas:
I started to work with phasors , I converted all the sin() functions into cos() like
\$2sin(2\omega t+\frac{\pi}{6}) = 2cos(\frac{\pi}{2}-(2\omega t+\frac{\pi}{6})) = 2cos(\frac{\pi}{3}-2\omega t) \$ then complex phasor \$e^{j(\frac{\pi}{3}-2\omega t)}\$ so i this this procedure for every trigonometric function in \$ u(t) \$ and \$i(t)\$
then i used the following formula:
and then simplified the whole expression, i hoped that the exponents will turn out to be the same but they differ.
This question is a small part of an signals and systems exam it's going for 2 points out of 30 so i am guessing (since my calculation taking so long) there is a faster and simplier way to get the right answer ? The following picture is just showing that all the exponents are different:
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
