-6
How can a program from an AVR be recovered when its lock fuse bits are set?
closed as unclear what you're asking by Leon Heller, Bimpelrekkie, MCG, Finbarr, Dwayne Reid Jan 11 at 19:19
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Question doen't make any sense! \$\endgroup\$ – Leon Heller Jan 11 at 11:24
  • \$\begingroup\$ Edited the question, I think this is what the question meant to ask. \$\endgroup\$ – Renan Jan 11 at 11:34
  • 5
    \$\begingroup\$ This is not the right place to ask for assistance with software piracy. \$\endgroup\$ – Dmitry Grigoryev Jan 11 at 11:35
  • \$\begingroup\$ Etch the plastic top off, make holes in the passivation layer with an E-beam and start probing. (humm, maybe I should turn this into an answer...) \$\endgroup\$ – Oldfart Jan 11 at 11:47
  • \$\begingroup\$ The point of the lock fuse bits is to lock the device. You need to hack the device to read the code. \$\endgroup\$ – Puffafish Jan 11 at 12:24
If you are asking, "How can I recover a program from an AVR microcontroller when the fusebits are set to protect the code?" then the answer is that you can't. That's what they are for.
  • \$\begingroup\$ You can't easily but there are ways to get around those limitations, but the effort required is often not worth what you get. \$\endgroup\$ – Arsenal Jan 11 at 14:27
  • \$\begingroup\$ ... but if you have the resources to undertake that effort, you certainly don't need to ask how. \$\endgroup\$ – Brian Drummond Jan 12 at 17:04
