So I've been trying to control a motor using a MOSFET transistor, where the gate is controlled by a raspberry pi.
My circuit is wired as follow: Circuit wiring
The diodes represent the raspberry pi ground and gpio pin 17
The problem is that when the pin #17 is set to high, the motor should stop, or at least drastically slow down, but nothing happens. Help would be greatly appreciated, thanks.
The transistor model is the IRF730
Edit :
Ok, first sorry for the mess of my first post; second here is the transistor data sheet: http://www.vishay.com/docs/91047/91047.pdf
and the proper schematic I've done to the best of my knowledge:
  • 4
    \$\begingroup\$ Please draw a proper schematic. You have resistors floating out in space and connections that are hidden underneath the transistor body. You should also provide a link to the transistor data sheet. \$\endgroup\$ Jan 11, 2019 at 22:11
    \$\begingroup\$ The reason we ask for a schematic is that it shows the schema of the circuit and the function of each pin. What you have provided is a wiring diagram and without having to read the datasheet for the device we have no idea which pin is which. There is a CircuitLab button on the editor toolbar and it is very easy to use. You can use the LAMP symbol to represent the motor. \$\endgroup\$
    – Transistor
    Jan 11, 2019 at 22:28
    \$\begingroup\$ Assuming that's really the way you have it connected, you've connected the Raspberry-Pi GPIO pin and ground to the FET's gate. You need to connect the R-Pi's ground to your circuit ground. I can't remember if the R-Pi's GPIO is 5V or 3.3V -- if it's 5V that FET will be marginal; if it's 3.3V it probably isn't enough. You want a logic-level FET. \$\endgroup\$
    – TimWescott
    Jan 11, 2019 at 22:29
  • \$\begingroup\$ @Transistor: true, but the OP seems to be a rank enough beginner that they may not be able to do a schematic. If they can, though, they should. Witness questions like this one: electronics.stackexchange.com/questions/86028/…. \$\endgroup\$
    – TimWescott
    Jan 11, 2019 at 22:31
The R'Pi is a 3.3V MCU so has insufficient voltage output on the GPIO to use the IRF730 you have.
To make any progress you need to be able to understand the components you are using.
  1. Your MCU. R'Pi output is only 3.3V. You should be able to measure this using a multimeter. Set the GPIO pin high and measure the output voltage, it should be 3.3V. Set the GPIO low and the output in should read zero.
  2. Your N-channel FET, the IRF730. This is an unusual device to select, but you should be able to make it work with some minor modifications to your drive.
For your FET you critically need to understand the gate voltage used to turn it on.
This is specified in the datasheet and you should put effort into understanding the datasheet if you expect to experiment further.
From the datasheet:
The above table shows that to get just 250uA of current to flow from Drain to Source you need at least 2V and perhaps as much as 4V on the gate.
So this device is likely not to work at all with a 3.3V MCU GPIO output.
The chart above is typical characteristics and shows that with a V(GS) voltage of 4.5V you typically would not be able to pass much more than 200mA from Drain to Source.
In any design you should ensure you have enough drive to ensure the device is driven at a voltage suitable for your load current.
In your case with a small motor (as shown in your diagram) you'd expect current flows in the 50mA to perhaps as much as 700mA under load.
Since you have a 6V battery to drive your motor, you do have enough voltage to drive the gate, you just need to interface this to your R'Pi.
A schematic that would work for you is shown below:
The extra transistor interfaces the 3V3 output level of the R'Pi to the 6V level of your motor battery. A high on the GPIO pin cuts off the transistor and R1 pulls the gate of the FET to 6V to turn it on. This is more than enough to drive your motor.
I said the IRF730 was a quite strange device selection. This is because it's a very high voltage device with an avalanche body diode. Most schematics you see driving DC (brush) motors include a diode to prevent a high voltage kick when you turn it off. D1 would 'catch' this energy. However because the IRF730 includes an avalanche body diode you can allow this back EMF to occur, it is clamped at the avalanche voltage which is guaranteed to be above 400V. So in this particular circuit you could leave D1 out.
I leave it to you to be able to translate the schematic into a breadboard layout.
Update: The choice of FETs used tends to start religious wars with each EE having their own favorite devices to use.
There are many 'logic level' FETs produced, but sticking with your choice of a TO-220 case which is easy to work with you could try the IRF3709. This has very low RDS(on) even at 3.3V gate drive.
My personal favorites are the Alpha&Omega SOT-23 range for general purpose N and P channel FET I/O. Consider devices such as the AO3400A which is easily driven from 3V3 logic and with very low (<50 mOhms) RDS(on). The very low RDS(on) results in extremely low device dissipation in PWM applications.
  • \$\begingroup\$ All right, thanks for all of this, but you said the IRF730 was an odd device choice, due to the low voltages used in the circuit, thus what type of transistor should I be looking for? \$\endgroup\$ Jan 12, 2019 at 6:19
  • \$\begingroup\$ @matkiller333 I updated the answer with a couple of device selections. \$\endgroup\$ Jan 12, 2019 at 7:13
From the fritizing diagram that you posted, it looks like this is your circuit, with the motor modeled as a resistor (really squinting here to see what G, D, and S are on the generic NMOS part that you placed...please follow Elliot's comments for future posts.)
A couple issues:
  1. The GPIO pin on your Raspberry Pi and ground are shorted at the gate pin of the NMOS?? This alone will prevent the NMOS from switching, and will destroy your GPIO driver, since you have a zero-impedance path between the GPIO 3V3 and Ground rails.
  2. It looks like you have the drain and source pins switched. Your N-MOSFET is currently set up as a high-side driver, but it needs to be in low-side configuration, since the \$ V_{GS} > V_{thresh} \$ condition must be met for it to conduct.
Here's a general schematic for what you should have, but this isn't too much help without part numbers and design requirements.
  • \$\begingroup\$ Unfortunately with the IRF730 device selected the R'Pi is unlikely to be able to turn it on enough to make the motor turn. The VGS(th) is 2-4V. The IRF530 shown here has the same VGS(th) and is therefore just as unlikely to work. \$\endgroup\$ Jan 12, 2019 at 4:14
  • \$\begingroup\$ @JackCreasey yes, you’re right. I didn’t mean to suggest using the IRF4530, it’s just the default schematic part :P I wanted to just introduce the general practice of driving loads with a MOSFET. Depending on the motor and expected load, I was suggesting that if a MOSFET could be found that can be driven from 3V3, this is how you would connect it. \$\endgroup\$
    – Rahul Iyer
    Jan 12, 2019 at 5:20
