I have a LED string with four different lights. The lights are in order red, green, yellow and blue and this pattern is repeated. It has a controller with a button to cycle through fading/blinking modes. All red and yellow lights form a group and all green and blue lights form a group. The lights in a group are always on at the same time and equally bright.
Controller
First (left) and second LED:
Wiring:
  • Two wires are going from the controller to the first LED.
  • Every LED is connected with two wires to the previous LED and with two wires to the next LED.
  • There is a wire from the first LED that skips the other lights (I thought all other lights, but I didn't check them all, still have to check) and goes into the last LED, so three wires are going into the last LED.
I expected there to be three wires from the controller to the first LED, one for each of the groups and one common wire that is either + or -. How can two groups of lights be controlled independently with only two wires?
Based on the current answers I drew this diagram, but I'm not sure if it's right. I still have to count the LEDs to see if it is possible with the 31V output specified on the adapter.
Schematics
  • \$\begingroup\$ Can you double-check. It looks to me as though the wire that skips the first LED is connected to the second one and that one of the other wires skips the second one. \$\endgroup\$
    – Transistor
    Jan 13, 2019 at 14:44
  • \$\begingroup\$ @Transistor I don't have LED string here, but I checked like 6 in row at a few places. But maybe the wire only connects at 4 points or something to get 4 parallel circuits. \$\endgroup\$
    – Paul
    Jan 13, 2019 at 14:46
    \$\begingroup\$ The 31 V spec on the PSU is a clue. How many LEDs in total? \$\endgroup\$
    – Transistor
    Jan 13, 2019 at 15:39
  • \$\begingroup\$ Your sketch would be a typical way to do it but there are two wires in and out of the second LED in the photo. \$\endgroup\$
    – Transistor
    Jan 13, 2019 at 16:14
  • \$\begingroup\$ @Transistor That is compatible with the sketch if the top wire goes in and out the second LED tape without being connected to anything. \$\endgroup\$
    – Paul
    Jan 13, 2019 at 16:19
I expect there is an ordinary diode across the two pins of each LED such that when driven in the forward direction the LED lights and in the reverse direction the diode conducts. This diode is hidden in the black tape under the LED.
If a series string of these LEDs is formed where the one color (eg blue) is connected one way and another color (eg yellow) is connected in the reverse direction then the blue will all illuminate with positive current and yellow with negative current.
Two of these strings can then be assembled with a common return wire resulting in 3 wires in total. (put different colors in the second string).
The controller has to provide one polarity or the other depending upon the combination required.
The AC supply provides a convenient way of providing the two polarities.
Since each LED will be driven with 60Hz, flicker is normally fairly noticeable in the LEDs, especially if you move your head (or the LEDs) when viewing them.
  • \$\begingroup\$ Wouldn't a diode on every LED be too expensive? I think diodes can be avoided with extra wire. Or is this common practice? \$\endgroup\$
    – Paul
    Jan 13, 2019 at 16:11
  • \$\begingroup\$ @Paul - it would cost but maybe cheaper than the additional wire and its connections. \$\endgroup\$ Jan 13, 2019 at 17:21
Probably something like this:
This arrangement has 2, 3 or 4 wires between the LEds. but is compatible with what's shown in the photo.
  • \$\begingroup\$ That would colocate two LEDs or require more wires between adjacent LEDs. I suspect there is a hidden ordinary diode across the LED that is hidden in the black sleeving in the picture. \$\endgroup\$ Jan 13, 2019 at 4:45
  • \$\begingroup\$ note: D7 - 2 - wires - D6 - 3 wires - D5 - 3 wires - D4 that matches the wire counts in the photo. \$\endgroup\$ Jan 13, 2019 at 5:09
    \$\begingroup\$ But you've got four wires between D1 and D2. \$\endgroup\$
    – Transistor
    Jan 13, 2019 at 15:40
  • \$\begingroup\$ my guess is that the original poster miscounted. \$\endgroup\$ Jan 13, 2019 at 20:56
